maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Tue Jan 17, 2006 2:04 pm
You'll just have to check the bulb when you remove it, to see if it's commercially available or if you need to go to a dealer.
For the removal, as you said, start with removing the screws from the bezel surrounding the cluster. There will probably be some metal tabs holding the bezel in; just firmly pull the bezel out straight once the screws are removed. Disconnect any wiring.
Next there will be at least 3 screws securing the cluster housing. Remove those, pull the housing out a bit, disconnect any wiring connections, and fully remove the cluster from the dash.
Finally, you have to be very careful, and push out the tabs holding the clear plastic face piece to the cluster housing. Once you reach this point, it's up to you. Use the breakdown picture above for ideas on how to remove the remaining components to access the bulb.
