Gauge cluster warning lights wont go out when key removed?
TwoJayZee240
Car: 93 RB25 powered hatch
I am just about done with my rb swap. I put the key in to see if i did the wiring right and if it would turn over and it does. But when i remove the key the light still stay on in the cluster. (EX- brake - check engine- seatbelt) I know it is not the harness since when i dissconnect the dash connector the lights still stay on. Here is a pic.
AZ89two4Tsx
Try turning off your headlights.
TwoJayZee240
They are off and in the down position.
johnny5
Car: 91 red 240 hatch
make sure your key is fully off, i know ive done this a couple times cuz my key is so worn i can pull it out with the car running,
AZ89two4Tsx
Well I'm stumped then. Good luck!
TwoJayZee240
johnny5 wrote:make sure your key is fully off, i know ive done this a couple times cuz my key is so worn i can pull it out with the car running,
I turn the key off in the and pull it out normaly. Only thing i can think of it being is a bad ign relay, or cbad grounds due to recent engine bay painting...
