Gauge Cluster
Drty_Jrze
I just put in a 92 cluster. I just disconnected the old one and plugged in the new. Will it read everything properly or is there some rewiring that needed to be done? RPM's and everything else looks good. Just want to make sure so that I don't think that I have some gas and I'm riding around on fumes...Thanks.
SpeedRacer1
Car: 1990 240SX, G35
Shouldnt be any problems if you did the dash wiring by the ECU properly.
Drty_Jrze
So if I plugged the harness into the properly corresponding slots, there shouldn't be any problems correct?
SpeedRacer1
Nope no issues, depending on who does your dash wiring, the Check Engine light may never work. But that just might be in my case alone.
Drty_Jrze
O.k then everything is fine. Thanks for the help.
