Gauge Cluster
theboz
Car: 1990 240SX coupe SR20DET, 1995 S14 SE DD, 1995 Civic Hatch, 1993 GMC 2500HD, 2004 Suzuki XL7
I have a 95 S14 SE. I have the white face gauges. My speedo is broken and I am wonddring if I can use the cluster out of a non SE. It has all the same gauges just are not white face. If anybody know please inform me before I buy any parts. Thanks,
BoZ
kouki munster
Car: 97 base 240
The clusters are the same other than the color of the gauge faces, just make sure you get a 95-96 cluster as the 97-98 clusters have different plugs.
Are you sure that the cluster is the problem? Make sure that there are no broken wires and the speed sensor is securely plugged in. Also, search nico for a fsm for your car and run through the test procedures for the speed sensor.
theboz
Thanks for the help. I checked the pugs and wiring. Everything checks out. It is the speedo itself I think. It would read 43 mph until I jiggled the knob that zeros the trip meter. Then it would work again for a wile......then just drop back to 43 mph. Then tug on or jiggle the knob again. Kind of annoying when I don't know how fast I am driving.....lol. I appreciate the help.
BoZ
