UMS_CA18DET »
https://forums.nicoclub.com/ums-ca18det-u41649.html
Sun Sep 03, 2006 3:38 am
actually the speedo should work regardless of motor, the tach should work also but will be wack like you'll be revving at 2000rpms and the tach will display 500rpms. I have used all the clusters from SOHC Analog and Hud to DOHC Analog and Hud, everything worked except the tach when put on the wrong motor. I currently did away with my stock ecu in favor for a standalone and had to wire things up differently so now my tach works for whatever motor.
The reason the tach doesnt work from SOHC to DOHC is because the DOHC reads the rpms at a different voltage than the SOHC one.
