Gauge Cluster Stuck trying to get LED Gauge Lights Please Help.
RustyShackleford
Car: Red Piggy w/Black Meshies
Well I'm trying to replace the gauge cluster bulbs with new led bulbs and I've read two guides but when I get to the part of removing the plastic cover it gets stuck behind the steering wheel adjustment knob any tips? Here's some pictures. The thing circled in red is blocking me. I'm trying to take the yellow highlighted part off.Thanks in advance. Merry Christmas
shanelach
Car: N/A
When i removed mine i squeezed it and turned it clockwise and pulled it off that way. easier said than done though. be VERY gentle because it cracks very easy. remove the steering column covers and steering wheel for extra space also. Good luck!
japslapsilvia
Car: 90 s-13
just drop the column there are 2 bolts under it that you can remove and the whole column will drop
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
Your best bet is to drop the steering column.
crsilvia13
Car: 91 white coupe
the way i did it was to take all of the plastic parts off then you look under the steering column there should be two main bolts take those off and you can push the steering wheel pretty far down. and as for the led lights its very simple take the cluster out and get your leds from superbrightleds.com then use the wedge bulbs and it should look sick i have red in mine
s13_chris
Car: 90 240sx Hatch
I hope he wasn't waiting this long for a answer..
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
drop the column.....
94_240sx
Car: 94_240SX
NISSAN240SX12 wrote:drop the column.....
Two 12mm bolts are holding it.
