AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.html
Sat Nov 07, 2009 9:08 pm
There should be two big goldish bolts under the column. Pretty big size too so they're hard to miss. You have to get way under there and will need an extension. 15mm? 16mm? Idk, it's metric though.
After you take those out, yank the column down as necessary. Don't worry about pulling it down too far, it won't hurt anything.
You're gonna have to pop off the gauge bezel/trim too. Not all the way, just far enough to get the cluster out.
This is for an s13 btw, I've never had to pull an s14 cluster, but I imagine it's the same idea.
So yeah, two big bolts under the column.
