gauge cluster questions
blackbeltclub99
Car: 93 RX7
ok my HUD does not work. The odometer and tripometer work fine just no speedo. Since the milage rolls over fine would an analog cluster work?thanks in advance for your help
sr20240sx
Car: 2000 Anniversary Q45T
It _should_... If you get an analog cluster though you will need to get the short harness that plugs into the main harness though, as these two are differnt between the analog cluster and the digital one. Hope this helps!!
-Brad
