Checked:
-Relays (ACC, IGN, and ALT) (Figured these out through other post)
-Fuse (Meter)
-12V power to gauges ( I believe all three connections are getting them)
So I have yet to check the grounds, I heard there are 4 in the car that I am supposed to look for. Also the dash lights do not come on, but my tail lights work fine so I don't think its the TLC. On the cluster I do get the low gas light as well as a check engine light due to my recent dual cam swap. Also the blinker lights do work too. Besides that nothing works. I was thinking that it could be the speed sensor and the sending unit for gas, but I decided it wasn't because the temp doesn't work either. Also if it was the sending unit why am I getting the low gas light (making assumption that sending unit works now because of this). So overall what I'm trying to figure out is why the fuel gauge, speedo, and temp are not working nor is the dash lights on. Like I said before the gas light works, blinkers, and check engine light works. Forgot to mention that the tach does seem to jump up when I start the car, but being that I have the swap it doesn't work. The speedometer doesn't move from 0.
I am also curious to know which wires are the grounds so I can try to trace them back. Maybe someone can tell me the proper wiring so I can make sure the wires are in the right pins. I know I've seen a post about it somewhere,but can't seem to find it.
I'm hoping the cluster isn't bad, but can it be even though the info lights work?
Thanks in advance for all the help
