biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Mon Mar 28, 2005 5:56 pm
speedo off may be due to using the CA's speedo sensor, as it expects a 4.36x final drive, not the 4.08 your going to have on your 240sx. swap the sensors out from the KA transmission to the CA.
Also, you do need a KA24DE or SR20DE/T or CA18DE/T (SR/CA for S13 obviously) tach.. I forget if the tach is swappable from HUD to non HUD.. if it is get a DE and swap it over, otherwise you're up a creek, find a working DE HUD cluster ($$$$$ and hard to find) or go without HUD.
