gauge cluster not lighting up
s13drifterbabe
Car: s13 fastback
My gauge cluster on my 91 fastback doesn't light up at night when I turn on my headlights. But my turn signals will blink on the cluster when I use the turn signal. Which fuse should I look for in case it's a fuse problem?
I noticed that there is a fuse missing where it says "Daytime Light 10A". What is daytime light? Is there supposed to be a fuse there?
efrain240sx
Car: 1992 nissan 240sx HB
day time light is for the clock it turns on when you turn on ign.
s13rb25det
Car: 92 240sx w/rb25det
its probably your dimmer switch its bulb some times acts as a fuse and if its burnt out your dash lights will not work
s13drifterbabe
Car: s13 fastback
efrain240sx wrote:day time light is for the clock it turns on when you turn on ign.
There is no fuse for the day time light and my clock lights up when I turn on my ignition and it will turn off with my headlights on. Is that how it's supposed to work?
s13drifterbabe
Car: s13 fastback
s13rb25det wrote:its probably your dimmer switch its bulb some times acts as a fuse and if its burnt out your dash lights will not work
My dimmer switch doesn't function at all and it doesn't light up either. I think you may have hit the source of the problem.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Do you have the digital cluster with HUD?
If so, common problem, thoroughly discussed on here. Search and you will find ways to fix it.
s13drifterbabe
Car: s13 fastback
1991S13 wrote:Do you have the digital cluster with HUD?
I have an analog cluster.
