So if one bulb in the main portion of the cluster (3 large bulbs) is burned out then none of the three will work?amolao wrote:I just checked the wire diagram and I really think the problem is specific to your cluster. Check the wiring and connectors for broken/burned leads,etc in the cluster harness. But the cluster main lightning is wired together, as in all the main light work or they don't....
hope this helps...
Alright, first of all thanks a ton for your helpamolao wrote:No, they will work. They are wire together as in the main illumination voltage coming into the cluster and going to all the lightbulbs. If you loose the illumination voltage somewhere before it gets to the cluster, then none of your lights will work. If you have the Ill. voltage in the cluster ALL your lights "should" work UNLESS there a bad/burned track/wire to that bad specific lighbulb or bad lightbulb...sorry if this confusing...
Tell me something, when you have your headlight switch turned to "parking lights" are you still getting the same problem??
You probably checked this already, but have check the actual lightbulbs to see if they are bad???
Well we're making progress . That diagram will help a lot. I'm pretty convinced like you said that it's not in the cluster any more... Although the TCM *looked* fine, i think that still might be the culprit. I've gotta find out which wire coming out of it is the ground (black i'm assuming) and test that.amolao wrote:Whoa...I read your posting a few times and I thought you said it was only tach and speedo light that were out....dont worry is cool. IF all your lights (dash and cluster) are inop, then is your TCM or in between.
But if you have black tape over the two right bottom lights, thats a very bad sign. Somebody messed with that cluster before. I would buy a used cheap one and play with this one when you are bored.
Those two empty light sockets are used on specific models (engine light, cat temp indicator,etc).I have done work on these before and is not that hard, you sound pretty motivated and willing to get this cluster working.
You are saying that you have voltage going to the lightbulbs, then you are missing ground, and if that's the case you are missing ground in a common point where is affecting ALL of your lights.....check grounds coming from the TCM. We are gonna give hell to this thing until it works!!!!
This morning I tested the harness for the TCM as directed by the factory service manual. I followed the directions and according to it, the TCM was bad.flipture wrote:Well we're making progress . That diagram will help a lot. I'm pretty convinced like you said that it's not in the cluster any more... Although the TCM *looked* fine, i think that still might be the culprit. I've gotta find out which wire coming out of it is the ground (black i'm assuming) and test that.
I have a friend that has a couple extra 240's that he uses for parts so if i don't get this figured out by friday i'm going to go over there and get his help and try another cluster and swap out the TCM...
Any way i can bypass the tcm or something? Maybe try to ground something out from the TCM to see if that is the problem? Can you explain what it does exactly too??
And yes i am very motivated to get this fixed i like a challenge... i learn a lot
Ok, that makes sence... Since i changed out the tcu (might still be bad so i'll try another one friday when i get to my buddys, they have a couple junk 240's) and it still doesn't work, is there a way i can maybe try starting in the light cluster from where it goes in and grounding it light by light to try to find out where the break is and if it's even in the cluster? My buddy also has some clusters we're going to try but i'd like to get it figured out before friday...amolao wrote:The illumination path begins at the light switch, from them goes to the TCU or TCM where is regulate by the dimmer switch and from there to all lamp circuits...including radio, dash,etc....
Think of the TCU as the local electric company, it manages,regulates and provides the path of light....without it there will no lights. Even though, the actual illumination comes from the light switch, the TCU is the component that "applies" the right signal and voltages for you to be able to see your dash and cluster at night.
The illumination path is kind of complicated, it works in a loop principle. You break the loop anywhere and you have no lights. The TCU is the main item in the loop.
Bottomline:
Check all fuses again.Swap the TCU, is fairly easy and a quick test.Pin 6 of TCU is input and 11 is output. From there it goes to all lamp circuits.
I did check the head unit, the guy who hooked it up had the ground wire grounding to the back of the head unit which was making it ground through the antenna... i changed it so that it is being grounded off one of the bolts that holds down the shifter...ricebike wrote:side step: did you also make sure that the aftermarket head unit wires are correctly matched up? it should also have a separate ground wire to the chassis... & the illumination wires should be untapped/ taped off...
Ok when i tested thsi morning i tested with the TCU *NOT* hooked up... maybe this was my mistake. I will re-test with it hooked up and see if i get the correct voltage. I seriously doubt its the switch since if it was a significant enough short to melt that it would have smelled and the guy that shorted it said that it didn't make any kind of smell... i won't rule it out quite yet tho...amolao wrote:With ignition/key off and light switch ON check between pin 6 and 15, make sure you have the pins right, see the FSM layout if not sure. Pin 6 should have 12 volts and 15 is ground. Positive lead on pin 6 and negative lead on 15. You will be checking for these from behind the connector with everything hooked up IF...
you have 12V, then you have the right output coming from your TCU. IF NOT...Then check the harness between light switch and TCU. One thing maybe also you will need to check is the light switch, if is your light switch this will be a first one.....Maybe the short created during the installation of the radio was significant enough to damage the terminals in the light switch.... ,and also make sure you dimmer switch is all the way up.....
99% of the time is the TCU. But you never know. But by trying another TCU I think we can say the problem is somewhere else.
Well i'm not seeing the strange problems like you mentioned. They just simply don't turn on. I tested one diode and it had continuity, and the other did not but i only tested in one direction. I will try both this time. I just read through your thread so now i think i have a better idea on how to test them...amolao wrote:They are diodes, my friend....not resistors. Check this link:zerothread?id=96108
This one the first time I had problems with a cluster, I had bad DIODES on mine, and it shows how to test them and the symptoms I had back them. Yes, those diodes are in your illumination path but if they go bad they will affect your car in a different way.
Lightbulbs are hooked in parallel, if one goes bad, the other will continue working, for safety reasons. You can pull your cluster off your dash and your car will run fine, again for safety reasons. If you were to suffer a catastrophic failure in your cluster while driving, your car will continue running somewhat safe and without problems.
