chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Fri Sep 02, 2005 9:43 pm
i changed mine out in my s14 after one of the stock ones burnt out. i changed them with some 50 cent white leds off ebay. it came out looking purple, which is kindof wierd, but kindof cool. i want to change them to red later on. also changing the bulbs is super easy in s14 (cant speak for s13). you dont have to drop the column or whatever.
heres my awesome s14 bulb mod guide.
1. unscrew the gauge surround, throw away the screws you pull out, the thing snaps in real snug so no point for the screws. just makes it less hastle the next time you mess with it. it dosent rattle or anything. unplug the dimmer switch and, if equipped, cruise control button. to get the thing out, put the steering wheel tilt to full low, and wiggle it around and stuff. set aside.
2. there will be 3 screws on the gauge cluster, one on top center and 2 on bottom corners. unscrew these. they will have black goopy stuff on them. set these aside, dont get the goopy stuff on your hands, it makes a mess.
3. gently pull the gauge cluster out. be careful not to pull just the clear sheild thing off the gauge cluster, you want to remove the entire gauge cluster.
4. look on the back of the gauge cluster for little quarter turn plastic things. i think they say LED next to them, not totally sure. basically anything without a plug is a lightbulb. the ones at the bottom are for turn signal and engine check and all that crap. but yea once you locate the gauge cluster things (there should be 3) turn them 1/4 turn and they will pop out. pull lightbulb out, replace.
5. read previous 4 steps in reverse, complete.
