Gauge Cluster lights out after LED bulb Install
Will Goes Boing
I did a search but couldn't find the answer I need. Today I swapped in some LED bulbs and the cluster lights wouldn't turn on. I tried swapping the old ones back in and it still doesn't work.
So I thought it might be a blown fuse but I checked all of them and they're all fine. The oil/brake/etc lights still work, and the tach still works but just no lights.
So if its not the bulbs and its not a blown fuse what else could it be?
Will Goes Boing
Nevermind......... I plugged the harness to the dimming switch and it turned on
The clock light still doesn't work though, I tried the new bulb and old one, and used a different twisting base (not sure what you call those) that you stick the bulbs into and it didn't work.
LayNLow240
Car: 92 240 coupe
Wait, are you saying the clock in the cluster is supposed to light up? Son of a B...
ahmonrah
Car: 1993 nissan 240sx hatch
LayNLow240 wrote:Wait, are you saying the clock in the cluster is supposed to light up? Son of a B...
you thought it didnt??!! lol!! but yeah it does light, hopefully by now you've got yours working man...
Vegascorbin
Car: 1990 240sx dirt track race car
If you have just one bulb not working then you probibly need to reverse it in the socket. Regular bulbs can go in either way but LED bulbs usualy only work one direction. There are some Bi-directional bulbs available but the cost more.
Just try reverseing the bulb in the socket.
