Gauge Cluster LED change / removal
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Nissanlatio
Hi pplz, anyone had luck in changing the LED in your Gauge Cluster? I have managed to take out the cluster unit but when i tried pulling out the gauge needles, I couldn't pull it out. I know that the lights on the gauges (amber) are emitted from the LEDs (surface mounted type) that were soldered on the PCB board and i had to remove and change the LED. Before i do that, the needles are getting in my way. Anyone can advise if the needles are 'pullable'?
Many thanks folks! :)
Return to “Versa Technical Discussions”
