moso wrote:chances are they are not wired in at the ecu to dash connection. you would need to do it yourself.
Do you mean the brown connector that branches off of the blue ECU connector? If so, that is all wired up.
compactfean wrote:If oil pressure doesn't work, that's not in that bundle of wires so would be a separate issue.^ I doubt is a power supply problem though because all you're dummy lights use the same potter source as the rest of you're gauge cluster.
So you are saying the oil pressure has nothing to do with the rest of the dummy lights?
Everything worked perfectly when it this motor and everything was in my old car... I'm thinking there might be an electrical problem in the car itself?
