gauge cluster freaking out!!
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i just took out my gauge cluster because it was freaking out and put it back together but still freaking out the tachometer works perfect now but other gauges dont can it be the wires in the front engine where it connects to ecu?? engine is also a ka24de
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
http://www.nicoclub.com/FSM/240sx/91-94/EL.pdf
There should be some good info here, it could be the cluster ground, it is common for most.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i will for sure check that out as soon as its done raining thanks for the help :bigthumb:
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i am having a little trouble finding the ground can anyone provide schematics or take a pic of where it is??
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i traced the wires to the ground cleaned it but unfortunatly it is still freaking out
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
You might wanna just get a new cluster
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
probably everything except the mph gauge works :frown:
pj
Car: 95 s14
damn, it's opposite for me, mine everything works except the tach...it goes nuts constantly. havent been able to figure it out yet either.
Ni$$@n240
Car: Currently 1995 S14 Se
michael_grigoras wrote:probably everything except the mph gauge works :frown:
My brothers car has the same problem. If you smack the dash the spedo will work only for a moment though. If you figure it out be sure to let us know.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok so i took it apart and put a little oil on the spindle of each gauge works perfect now but might be because of the weather too when it was cold it wouldnt work today is a warm day and works perfect its either a bad ground or lose connection but the oil does helps greatly
Ni$$@n240
Cool Ill try that. Im thinking the harness plug that plugs into the cluster may be defective. One time I found a wire that wasnt 'snapped' into the connector all the way. So when you plug in the connector the wire would back out of the plug.
kyhunter89
Car: 1989 240sx 5 speed
Sweet you got it working. all mine work fine except the temp gauge will go to the red alot, and sometimes drops to cold...
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
I had the same problem a while ago it turned out to be my thermostat lol
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
Ugh another problem this time a water bleak in the left quarter panel gonna try taking it apart do they just pop off??
kyhunter89
michael_grigoras wrote:I had the same problem a while ago it turned out to be my thermostat lol
if it was the thermostat in mine it wouldve blew a long time ago.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
very true hmmm could be a lose connection possibly?
