gauge cluster differences
mynameisjonas
what are the visual differences with the SOHC gauge cluster and the DOHC one? i have two different clusters and i need the DOHC one for the sr20det swap.
VitaminT
Car: 93 240sx SE
Redline on tach? I can't remember what either one is but I believe it is different from E vs. DE.
bcar240
Car: 1993 240SX HB
One difference is tach, both visually (DOHC redline is higher) and electrically (SOHC tach will not work with DOHC engine.) The speedo is the same except for the markings, on the SOHC cluster it goes to 115 stopping on the 5s (35, 45, etc.) and the DOHC speedo it goes to 110 stopping on the 10s (30,40, etc.) Also, the SOHC cluster I saw didn't have a check engine light (it was a base model if that makes a difference,) it might have had the circuit for it, just no marks on the panel. Otherwise they should be compatable.
mynameisjonas
ok thanks alot, that helped. turns out i have 2 SOHC ones.
andrave
Car: 1989 Nissan 240SX Coupe
and the HUD and analog have different sized gauges, too... my dohc analog tach didn't swap right into my sohc hud cluster, had to swap faces and needles.
wangless
Car: '02 MBP WRX
funny thing, i just swapped the two before i read this thread.
my sohc hud tach went into my dohc cluster no prob, but not the other way around like andrave said. you could snip a little off the dohc tach to make it fit though lol
hey andrave, did you have any problems with the needle sticking after you swapped needles ?
