gauge cluster and reverse lights not working (im stumped)
BIGT94z
well on the way home from d!ck sporting goods my whole gauge cluster stopped working (rpm, mph, fuel, oil pressure) the lights/ clock still work though. so i check all the fuses and they are all good. so i thought it was the alternator. so i pull it off and get it tested at oriellys they tell me its bad so i get a new one. take it home install it and im still not getting a charge. so i test my battery its like 11. then i test to make sure i have power from the batery to the alternator and i do. so i take it off (altie)and get it tested it was good. so i was like and asked them to test my old one and it tested good. just to make sure ....i tested it at autozone too and it passed. so i decide to go up to walmart with a friend and he throws a seen about a 3 year old battery and gets my 70% off. so now its all good except my gauge cluster and reverse lights arent working. i have checked all the fuses so im thinking short? any help would be appreciated im stumped nico help me out
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
for the gauge cluster, its either the white box at the drivers side footrest or the control module under the center console (both are prone to breaking eventually).
is there voltage going to them?
BIGT94z
thanks man ill check all that stuff when it stops raining
BIGT94z
the damn thing wont even stay running now!!! i found a blown fuse elect. ignitoon fuse everything worked for like 5 minutes then back to normal. 30 minutes later my radio quit and then the car started joloting foward and wanting to die...lucky i got it home. it dyed half way up the drive way!!!
nizmo_dryfta
Car: '98 Altima '99 Altima '96 Sable crapped out, now searching for a 240
Did u have any other warning signs b4 the cluster went out
FSUDrifter
Car: trying to decide on one...
check your grounds and relays
574-240sx
Car: Nissans, Toyotas, Subaru
Check the harness under the front fender liners, they have a tendency to wear the wires down and some messed up stuff starts happening.
BIGT94z
nizmo_dryfta wrote:Did u have any other warning signs b4 the cluster went out
no i did not. ive checked all my grounds and there good the relays are the same. 574-240sx what exactly are u talking about...i can do anything mechanical but when i comes to electrical im like thanks for the responses guys
574-240sx
Check to see if the tire rubbed though the body harness or stripped some wires under the front fenders above the front tires.
k00laid83
also check the engine harness near the injectors or anything like near the engine and look for smoke! my buddies car was doing the same thing and was blowing fuses left and right. the problem was the plug that goes to the dist and the injector wires i hope that helps id check your engine harness. GOOD LUCK MAN!
BIGT94z
im bringing this back to life bc its doing it again i thought i solved it last time but i guess not. sypmtoms now is when u turn the on i get no dash lights (cel/abs/seat belt) like i usually do. the engine just cranks. i have checked all fuses/relays & reset the ecu. any ideas
Tech12
Car: 91 240sx Super Hicas
It's your ecu ground. The point on the engine where it is ground is right above the exhaust manifold. I'll be right back with a picture
Tech12
I know what happens because mine snapped off at one point. I moved it one bolt over.
There you go.
