DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Mar 03, 2005 12:26 am
Yes, fuel pressure gauge is all you need, and a brass 5/16" barbed T-fitting, plus maybe some extra 5/16" fuel injection hose. Make sure the gauge is for fuel injection. Most go to 100psi. I got some fuel hose pinch-off clamps from Harbor Freight for like $2 each, or you can use a couple vise-grips and towels to protect the lines.
I would think it's the seal and not the injector itself, unless the tip is cracked. To find out which injector it is I'm afraid you would have to pull the spark plugs. Only way I know how.
