If that's important to you, go to the 'top-tier' gas website. It is endorsed by BMW, as well as many other auto manufacturers.It does not mean if you get Costco gas your engine will rot. (Because Costco does claim to use 76, Phillips, or Shell depending on the area) but it does provide you with the major makers who explain the importance of quality gas regardless of octane rating.It's a good general guide. When in doubt, stick with name brand stations with a high turnover, you should be okay IMO.PGrated wrote:Here in the Northeast, many or all of the Mobil stations have been sold off to Valero.
I am usually pretty picky about the gas I put into My G35. I usually stick to either BP/Amoco, Mobil or Shell. Always 93 or better octane. Now, Valero is the new guy on the block. I was just wondering if anyone has had any good or bad experiences with their gas; and if its a decent brand to consider buying.
Valero is cheaper by about 4-5 cents per gallon than BP/Amoco. But, in the long run, I would rather spend a bit more money on better fuel than have problems with the car later.
I remember many years ago, BMW used to do tests on the quality of gasolines and would publish its findings on which ones were considered the best, cleanest, etc. I have not seen anything like this in recent years from them.
Thanks for the help.
pgrated.
I'm with ezflow on this! Had a BAD experience with a mom&pops type gas station years ago. I stick with PB/Amoco gas. I would also use only prem. I hate that pinging noise!!!ezflow wrote:
I doubt you would hear much pinging. The ECU will retard the timing if knocking is detected by the knock sensors. But the engine will not be operating at optimum performance. Makes one wonder why someone would believe anything the owner's manual says, but thinks when it says to run premium that are not serious.SVTCOBRA wrote:
You have a G!! Treat it nice!!!! Oh, IMHO......
Modern engines rarely ping on lower octane fuel. If you read up on it, or this thread you will know why.Might as well throw away the owner's manual, if you've read it. It does not know what it's talking about either if you want CR to be your guide. Show me where CR or the 'gov' says it's okay to run regular in a high performance engine. The breakpoint in compression rating is about 10:1. Much over that the engine will not be performing optimally. Besides a drop in hp at the wheel, fuel mileage can suffer, although not as much as the drop in power. The G35 has 10.3:1 and the newer G even higher. 10.6:1 I believe. The latest issue of Nissan Sport has a test run that showed a 10% drop in hp at the wheel with 87 octane fuel, and a 1mpg drop in mileage. And no pinging.Don't mean to beat you over the head with this info. I just don't think you are doing this car justice by running the same octane fuel as less powerful cars with lower compression engines.telcoman wrote:Here in Central New Jersey I see the same Island Transportation Tanker Trucks at many different branded stations. Even Hess which used to have their own trucks now have Island Transportation trucks filling their tanks.Our reg gas prices fell to $1.98 gal today. Within 2 miles of where I live, I have BP, Hess, Lukoil, Shell, Raceway, and Pittstop. I use whatever is cheapest. Consumer Reports as well as government tests conclude that for most vehicles regular 87 octane is fine. I have never heard a ping on my 2006 G35 6sp manual. It runs just fine on regular. For those that feel better in using premium thats fine but I think its just a waste of money. We are all driving a depreciating piece of metal. Don't get me wrong, I love the G35 but in ten years I'll probably be driving something else?
Telcoman
Maybe, but some folks can't get away with anything!SVTCOBRA wrote:Yep, I'm betting that you can get away with a lower grade with a manual.....course that's assuming you know when to shift...and when not to.
I have to assume Q45, (although I know where that has gotten me before), that you are referring to bpd of crude processed. This is an area I know something about, as I work in the oil industry in So Cal. You are absolutely correct about the fungabilty of gasoline, as well as the products used to blend it. The same holds true for crude oil.Q45tech wrote:Kind of like wine which vintage you buy:
Don't assume that the gasoline in the station tanks is necessarily made that day and every day by the same refinery. All gasoline is fungable and mixable as needed. When the tanker truck fills up a splash of marketing secret sauce is added to generic to make it the station label brand.
Sometimes the driver forgets or loses his eyedropper.
Bayway Refinery (ConocoPhillips), Linden, New Jersey 230,000 bpd Eagle Point Refinery (Sunoco), Westville, New Jersey 145,000 bpd Paulsboro Refinery (Valero), Paulsboro, New Jersey 160,000 bpd Perth Amboy Refinery (Chevron), Perth Amboy, New Jersey 80,000 bpd Port Reading Refinery (Hess), Port Reading, New Jersey 62,000 bpd
Marcus Hook Refinery (Sunoco), Marcus Hook, Pennsylvania 175,000 bpd Philadelphia Refinery (Sunoco), Philadelphia, Pennsylvania 335,000 bpd Trainer Refinery (ConocoPhillips), Trainer, Pennsylvania 185,000 bpd
I have to say, Q... if you are nothing else, you definitely are thorough!Q45tech wrote:One problem with blending gasoline from different refineries is you don't know how the mixture will come out octanewise..............it may be less, equal, or better than the simple sum of the two or three refinery products.
Octane is CALCULATED at the refinery based on component percentages.
The computer calculates what is expected with sum of all the components [historical actual measurements are averaged].
Brand new production gasoline degrades day by day as it goes thru pipeline and in storage at tank farms and in service station tanks from reactions with water and air.
Colonial pipeline:Speed: Moving about three to five miles an hour, a batch of petroleum to New York Harbor from Houston takes 18.5 days on average.
Plantation pipeline: Speed: One batch going to Washington National Airport from Baton Rogue takes 20 days on average.
Explorer Pipeline: Speed: One barrel of petroleum product going to Chicago from the Gulf Coast takes 11 days.
Living closer to the refineries has an upside if you are beyond the explosion zone.
Florida has NO PIPELINES AND is delivered by barges from Texas/ Louisana/MS
In Atlanta our gasoline from refineries to tank farm tanks is usually less than 7 days old and at high volume stations only last 3-4 days so worse case less than 14 days old in most vehicle tanks.
It's just simple physics as to why higher octane fuel runs better than lower octane fuel for higher compression cars. It is your car so it is ultimately up to you. Basically, the higher the octane, the harder it is for the fuel to detonate. Using lower octane might result in pre-detonation and loss in power, engine degradation, etc. Most newer cars can detect this and compensate, but still.telcoman wrote:Here in Central New Jersey I see the same Island Transportation Tanker Trucks at many different branded stations. Even Hess which used to have their own trucks now have Island Transportation trucks filling their tanks.Our reg gas prices fell to $1.98 gal today. Within 2 miles of where I live, I have BP, Hess, Lukoil, Shell, Raceway, and Pittstop. I use whatever is cheapest. Consumer Reports as well as government tests conclude that for most vehicles regular 87 octane is fine. I have never heard a ping on my 2006 G35 6sp manual. It runs just fine on regular. For those that feel better in using premium thats fine but I think its just a waste of money. We are all driving a depreciating piece of metal. Don't get me wrong, I love the G35 but in ten years I'll probably be driving something else?
Telcoman
That is the key right there.yelnatsch517 wrote: Most newer cars can detect this and compensate, but still.
