dyldorichardson wrote:I just purchased a 2003 g35 sport coupe and saw in the manual that 91 octane gas is recommended. Is it required to put premium gasoline in it? what damage could come from putting regular gasoline into the tank? just curious...
OK, googled your 2003 owner's manual to see if it's different from my 2004 and it is not.
The way I read the manual, it is
required not recommended for the coupe.
Unless, you can not find Prem. then, it is recommended that you only use enough regular to get you to a station that has Prem.
And, avoid WOT. (probably want to avoid hills too! Or, pulling trailer or hauling heavy people around too)
And, fill it up with Prem. ASAP.
This does not read as a recommendation to me.
Again, let me say that they make a distinction between the COUPE and SEDAN in the owner's manual.
