DenverQ wrote:I used to run 5-10w 30 in mobil1 but reading freds very informative articles i have now swiched to Valvline synpower 5w-40
Some recent developments on which members should be apprised:
Both MOBIL 1 And Valvoline SynPower have had a formulation change relatively recently.
MOBIL1 changed to their SS formulation which was greeted with much sceptisicm , from consumers experience with the last change ( which was from SH to SJ tri synthetic).The change to trisyn having turned out to be a step down in many PPL opnion.However the recent change of MOBIL 1 from trisyn (which was still sold some places as of a couple months ago) to SuperSyn seems to be more successful.
SuperSyn is in essence an attempt to make-up for the mandated (by API SJ and SL) low ppm of ZDDP with a new anti wear additive.
It does appear to have been success ful and in the new supersyn.Sadly the 0w-30,5w-30 amd 10w-30 MOBIL 1 viscosities still fall into the thinner range of what makes a 30 weight.for this reason alone I still stay away from MOBIL1 xw-30's.But the other weights of MOBIL1 are now very good.
Also it used to be impossible to find MOBIL1 0w-40 anywhere but at MB and Porsche dealers making it a non choice ( for lack of availabilty for most all consumers).Now however it is available at most autozones.
Valvoline SynPower used to be the only somewhat available 40 weight oil in or above a group III base oil.And it has recently slipped to a group III base oil.
As such Valvoline SynPower is still an excellent choice in 5w-40.However it is joined by MOBIL1 0w-40 in SS formulation.
Of the two, MOBIL 1 0w-40 has the better base stock, and SynPower 5w-40 is a bit cheaper and has good detergency in higher mile engines.
Making it anybody's choice at this point.
Fred...:thumbup
