gasket sealing questions?? PLEASE HELP
mugenrsx
So i have two oil leaks one from my oil pan and the other from my valve cover gasket i was wondering is there a gasket for the oil pan or do we use gasket maker, and what kind of gasket maker.
For the valve cover im wondering what type of seal do you use and where do you apply the seal??
Please help i have a blacktop s13 sr20
SpeedRacer1
Car: 1990 240SX, G35
You use RTV silicon for the oil pan and make absolutely certain it is all dry before filling it with oil again. You can get good quality RTV from Nissan or just use the auto shop stuff. There is a gasket for the valve cover that I am sure you have so just apply RTV to the cam lobe areas. basically in the semi-circles that go into the head at the front and back of the engine, 4 spots.
dsmtunermn03
Car: s13 240 hatch, 2000 Mitsubishi Mirage coupe "spudd"
ya you can get "right stuff" rtv at any any auto parts store. thats what i use at work, and ive never had a problem with it. make sure to let it dry for at least a half hour before filling with oil
Justin35ll
Car: s13 coupe sr20det
Yeah oil pan is liquid gasket and when I did my valve cover I applied a thin layer of it all the way around the head, but I think you only really need it in the half moon things
