Hello everyone,
I have a Sentra 2005 1.8S.
My car's engine needs a 15 second time to stabilize in every startup from shaking. I also see big bubbles when I leave the radiator cap off and start the car. The other thing is I need to top off coolant quite frequently, even after short drives(10 km for instance).
I was told by my mechanic that I need to replace the Head Gasket but since it is very hard to reach and replace head gasket in this car, he told me that it is cheaper to change the entire engine (Around 1500 CAD to replace).
The car also makes a very loud whistling sound mostly during startup (and also at random moments during driving).
I wanted to confirm with you guys if you also advise to change the entire engine as a cost effective choice or any other things I could check before doing that.
