Gasket question can't find.....
Florida240sx
Either I typed in wrong stuff or I'm an idiot today.....almost gave a guy a $1200 discount at work. I am strongly considering buying a turbo setup from someone.Can I just use a stock exhaust manifold gasket for it?from block to mani?and what other gaskets might I need?It has a downpipe.
Florida240sx
Bump...me being turboed is pending on my questions in the next 2 days. Found answers to all my questions so far except this one.
Craving4Boost
Car: 91 240sx fastback
yes you can use the same gaskets from your stock exhaust manifold....just make sure their not beat up in anyway...a lot of things need gaskets...mostly things that have a high chance of leaking things out such as air or oil. so you can kind of guess what things need gaskets...most of the things you buy are going to come with gaskest anyway
MarkEmark
Car: fully-built '95 240sx KA-T
Florida240sx wrote:Either I typed in wrong stuff or I'm an idiot today.....almost gave a guy a $1200 discount at work. I am strongly considering buying a turbo setup from someone.Can I just use a stock exhaust manifold gasket for it?from block to mani?and what other gaskets might I need?It has a downpipe.
I've got some brand new, never used OEM Nissan exhaust gaskets (4) that I needed to special order from Nissan (and therefore, cannot return) @ $11.99 a pop! Make me an offer if you want them....I also have a ton of other gaskets too that I'll put up for sale soon too...
Florida240sx
Gaskets are for ka24de correct?What other gaskets do you got.If I'm goign to have around 240ish rwhp or lower the stock exhaust gasket will be fine right?
Structure240sx
i used exhuast manifold gaskets from advanced auto parts $10 for all 4, they have been on for well over a year now. you need the gasket between the turbo and manifold (depends on the turbo) some people use one between the turbo and downpipe
MarkEmark
Florida240sx wrote:Gaskets are for ka24de correct?What other gaskets do you got.If I'm goign to have around 240ish rwhp or lower the stock exhaust gasket will be fine right?
Yes, they're for the KA24DE. I ended up using the OEM nissan gaskets but have a set of four Fel-Pro exhaust mani gaskets, in addition to tons of other gaskets. I just posted a for sale ad in the Nissan parts section of the forum.
zerothread?id=117626
Jookmasta
ya u could use the felpro gaskets or a copper gasket or both from mani to block. as for the turbo to mani, i use a ss gasket between it and my T3 has no gasket between backhousing and DP.....
Florida240sx
hey mark where's the ad? How much you want for them I want them most likely AIM florida240sx email:[email protected]
s13sr20chris
i have seen a few techs at my dealership reuse those exhaust gaskets with some copper rtv.
nissanfanatic
Car: 1992 Nissan 240sx SE
Structure240sx wrote:i used exhuast manifold gaskets from advanced auto parts $10 for all 4, they have been on for well over a year now. you need the gasket between the turbo and manifold (depends on the turbo) some people use one between the turbo and downpipe
Same here. I also used a gasket for turbo-to-downpipe from http://www.atpturbo.com Its a T04 downpipe gasket.
turbo90
Car: '90 240sx
same question, I saw a link to a site that sells copper exhaust-to-head gaskets for the KADE and KAE. Can someone hook me up with the link? pretty please they were about $50 for the set
