Gasket maker on turbo outlet
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
i had a small leak at the compressor outlet flange (maybe causing whining?)..i just went out and used Ultra Black RTV Silicone gasket maker in place of a new one. Thoughts?
C_MONEY
should work for a temp fix but i would be looking for the proper gasket to replace it with in the meantime
zach-Ka
Car: 1990 240sx (SR)
We tried using that on my friends down pipe and under the high temp. it cracked and blew out within a couple of days.I recommend getting a new gasket as soon as your finances permit...http://www.frsport.com/Turbo-Gasket_c_197.html
sjbsuperman1425
CA18DET
yea just used this to troubleshoot.
zach-Ka
Got ya. Did it at all fix the whining that you where referring to?
sjbsuperman1425
CA18DET
no. im thinking that maybe a really small boost leak might be causing that..theres another thread on here about it.
zach-Ka
If you have a air compressor and some plumbing fitting you can make a boost leak tester pretty easy.
zach-Ka
