gasket between turbo and manifold - is it needed?
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
I'd like to know if I could get away with not using a gasket between the turbo and manifold. If I don't routinely tighten the flange bolts, the gasket will begin to fail as shown. Thanks for any help!
superJoy
Car: 1989 RS13
Unless the surfaces are perfectly flat, it probably won't work. And even then, it seems a rather risky and complicated solution to a problem that's rather easy to solve.
Here's what Nissan did to prevent the nuts from loosening.
http://www.frsport.com/Genuine....html
That should keep your nuts in place.
mbmbmb23
superJoy wrote:Unless the surfaces are perfectly flat, it probably won't work. And even then, it seems a rather risky and complicated solution to a problem that's rather easy to solve.
Good link. Nissan uses these for a reason...same with the manifold to turbine housing gasket. Buy Buy Buy.
-m
float_6969
It won't do anything but make the engine bay really hot, possibly fumigate out from noxious gasses, and not allow your turbo to spool properly.
Other than that, you'll be fine.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
I say this in so many threads...
Your gasket is blowing because of the stiffness of your suspension, and/or the excess weight of your aftermarket exhaust and/or stiffer Nismo engine mounts.
Make sure the exhaust is fastened to the gearbox (not the vehicle body). This stops the exhaust trying to break off at the turbo gasket every time you go over a bump.
Use the Nissan gasket and the lock tabs available from Nissan. Cost $100 at most.
mbmbmb23
dattodude wrote:I say this in so many threads...
In the states you can get it for cheap, just get the turbo gasket for a Z32TT ...which is like $20 USD at most...then those locking tabs.....probably $40 shipped total.
trevr
Thanks for the criticism and help. Placed an order from the site listed above frsports.com for the t25 gasket, and bolt tabs, cost totaled $30.01 shipped.
My car is still suffering from the stock engine/transmission mounts, and suspension. I do have after market manifold and exhaust. My downpipe is equipped with a flex basket, which should reduce stresses of the road. All mounting points of the exhaust are anchored to its intended points of the car - just like stock.
I'm confident the gasket suffered from the bolts being lose, and a mixture of vibration and escaping exhaust was too much for it to handle.
Woods Crasher
Very interesting. So how does it work? Do you just put that on then bend the tabs over the nuts ?
AFSil80
Car: 1991 240SX fastback
Yup!
Simple but great design.
