sleek240 »
https://forums.nicoclub.com/sleek240-u14128.html
Fri Apr 02, 2004 9:37 am
I have a 1990 SE Hatchback with ~150,000 mi. Recently I have noticed an audible sloshing sound coming from the rear hatch area. It occurs whenever I come to a stop or take off from a stop abruptly.
I don't notice any smells or see any hanging support straps below the tank, so my uneducated guess is that the fuel pump may be loose in the tank and makes sounds as it gets pushed around.
The other reason I think this might be the case is that last night, as I neared the bottom of a tank while traveling on the freeway, I could feel the car hesitate as if fuel was not being fed to the engine properly.
I changed the fuel filter only 1 month ago, so I doubt that is an issue.
Any thoughts?
