allenms240 »
https://forums.nicoclub.com/allenms240-u128640.html
Mon Feb 01, 2010 7:36 am
Yeah you have to that that protector off. That's why you can't see the bolts right now. Then as said above you have to push the rubber piece out from the gas filler neck (Open the gas door and push what you put the gas in.)^^make sure fuel pump lines are off also, you have to remove the cover on the trunk to get to them, there are two of them. And also unplug the harness for it.What, clutch line? master and slave cylindeR? For what?I Though this waws about fuel.
