I will try that as to the level we only fill up when the tanks are about 1/4-1/8 full.yodawill2000 wrote:Mine has pressure.Switch gas caps to eliminate the cap as the culprit.
There are no Inspections in Floridayodawill2000 wrote:at 1/8th you should hear a hiss.
They test gas caps here in Texas on the State inspection.Do they not there ?
