gas tank leak
240_l3oi
Car: 1992 240SX SE ,120k miles. owned for 3 years
i have a gas tank leak after fill ups i dont know what its from i think i might be putting to much gas in it fills up around 13.4 gallons so im thinking i might have a small gas tank dows anyone know anything about his and or how big the gas tank is or how man gallons it hold thank you all for your support
navysnail
could be just the gas evaporating, see if you smell it the next day
jetmech1994
Car: 240sx
Might be the drain hose that runs along side of the filler neck in the wheel well.
NISTECH
You have a 15 7/8 tank capacity. 13.4 would be about right for a fill up as the tank probably shows near empty around those last 2 gallons. Can you see about where the fluid is dripping to the ground? Could be the vapor line as mentioned, pretty common for those to deteriorate on older model nissans.
babowc
Car: 240sx
sorry to bring this jank up..
but i went to fill up and after it stopped filling up, i just filled up a little more to make even 40bux(!) and suddenly i felt something splashing on my toe (wearing sandles)..guess what.. it was gas
what could be making the leak??
also, the car leaks if i drive around for awhile hard thru corners and stuff..
NISTECH
did you bother to look up under the car to see where it might be coming from?
ricebike
2002 Quest
2005 Altima
<shrugs> don't "top off"
when it clicks, stop... pay via credit card so you don't have to bump it up to the next dolla/quarter/etc...
