onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Mon Aug 18, 2008 6:34 pm
So I have a 95 240sx se, and I'm pretty sure it's a plastic gas tank for some reason. Anyways, smelled gas way bad in the garage yesterday, and sure enough there's little puddle of gas from a slow drip after filling up at the pump. Got under the car, and you can see probably a 1" long crack where the seam touches the strap that holds the tank up.
I drained out about half a tank by just running the pump into a gas tank....but it's all full. I guess I need to drive the rest out of it. Is there anything out there made to patch a plastic tank crack? Will JB weld work, or would some epoxy or sealant be better? How hard is it to drop the tank to fix it and what all do you have to do to drop it? Any help is great, thanks.
