dantesdoom »
https://forums.nicoclub.com/dantesdoom-u128282.html
Sun Aug 28, 2011 2:18 pm
Got a problem with my car. Took it our for an hour and half drive. Got back and there is a hiss at that sounds like it is coming from the gas tank when you stand outside of the car (with someone lightly reving it). I can even here it when i am sitting in the drivers seat with the window down. Its not quite the sound that happens with the fuel pump pressurizes the fuel system on start. It happens when i rev up to about 2K and sometimes stops a second after it starts, but other times you can hold the gas and it continues. It might continue on up the rpm band, but the exhaust overpowers it on sound so i cant tell. I wonder if i am losing gas pressure on rev and its working harder to compensate? Power feels fine, and this is the first time it has happened. I will check to see if it stops. But i want some suggestions just in case in happens next time i drive it. Doesnt quite sound like an exhaust leak, like i said more from the gas tank area. Suggestions please.
