Gas tank for 94 Altima
acuevas
Can naybody direct me to instructions on how to remove gas tank for above mentioned vehicle, thanks to all.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
why do you need to remove it? if just the pump, you access that from under the rear seat. no need to remove entire tank.also, don't forget to release pressure before uncorking any fuel lines. loosen gas cap with engine idling, then pull fuse for fuel pump until engine cuts, then crank engine 3-4 times and let die each time.
Modified by 3Q Jay at 9:56 PM 10/25/2007
acuevas
I think i need to remove to get to broken fuel line. I checked it out and it seems that all i have to do is drop the front part of the tank. can you confirm.
2008CodeRedCoupe
Car: 2008 Nissan Altima Coupe 3.5SE 6 M/T "Code Red"
which fuel line is broken? where is it broken? there should just be 2 or 4 bolts that hold the metal straps that hold the tank in, and you carefully and slowly lower the tank. after removing the rear seat and disconecting all electrical connectors and fuel line connectors of course.
