gas tank for 92 240sx
mosnismo
How easy is it to replaced this? Is there a writeup? Thanks
laxands13
Car: 93 240sx Hatchback - Sold and missed
80 280zx - sold
83 Honda Civic Wagon - Current DD, soon to be CA16 powered
from what i've heard (NOT personal experience) there are two straps holding it on from underneath and thats the main support. Don't just take my word for it, search for it too
EnjoiNismo
Car: 93 240sx
Its like a 1.8/5 stars to replace. We had to remove the fenderling on passanger side to get to a few bolts. But yes there are two big straps holding it also in place. Be sure to have the least amount of gas possible. (You will thank yourself for this)
allenms240
Car: 1991 Nissan 240SX
EnjoiNismo wrote:Its like a 1.8/5 stars to replace. We had to remove the fenderling on passanger side to get to a few bolts. But yes there are two big straps holding it also in place. Be sure to have the least amount of gas possible. (You will thank yourself for this)
^^^Agreed. make sure the lines for the fuel pump are disconnected as well.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
If you have too much gas you can siphon it out by removing the fuel canister located to the right in the back of your hatch/coupe. Even with 1/4 tank it will be heavy just a fair warning. Have a floor jack ready before you completely undo those straps.
angelscrx
Car: 1992 240sx
1 gallon of liquid equal 8 pounds of weight so empty is better.
mosnismo
do you have to have the car on a lift or does it have to be jacked up. thanks
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
if the car is stock ride height you can get it out with one jack, but I recommend two people and two jacks.
1. Take out fuel pump fuse/relay whatever and disconnect the battery.
2. pop gas door and remove gascap
3. remove rear interior so you can get to the fuel pump.
4. disconnect that plug after you unscrew everything.
5. remove grommet from the filler neck.
6. Start looking for bolts to remove the tank and take them out. I'd undo the front left strap and the rear right strap bolts only, so the straps stay there. Watch out for all the plastic shielding.
7. lower tank and undo the fuel lines, remember which one goes where. take off the evap line. Lower tank and if you have to jack up car and remove tank.
mosnismo
breadbox wrote:if the car is stock ride height you can get it out with one jack, but I recommend two people and two jacks.
wow thanks for the write up. I will follow this. Yes it is stock.
breadbox
89 Koop
84 720 4x4KC
Not really a write-up just What I remember from a few weeks ago.
Just don't smoke when you do it. Be very aware fuel catches fire,be safe, no sparks.
