Gas Tank Door? -94_240sx maybe?
johnny butt
Car: 1993 240sx Convertible
So this problem isn't as big as others I've had.
Although, I am having an overall bad day:-This morning I didn't have class until 2:30 PM so I decided I'd have a little spare time for myself this morning. So I figured I'd get a few things done on my car, few things done around the house, cook some steaks that I've had marinating in my fridge, and catch up on an assignment or two before my class. It sounded easy enough, until I go to cook lunch and somehow my mom put my steaks in the wrong part of our fridge and they were half frozen (seriously, who does that?!) On top of that, I wanted to drive my convertible around for a bit since the weather was nice (a little cold, but I wasn't going to drop the top.)
I needed gas, so that was no big deal. I went to the gas station right down the road and was going to get something out of my trunk and my key broke in HALF. I am sitting at the gas station with my car beside the pump, and now my one and only key is BROKEN. Luckily a friend spotted my car at the gas station when I was pushing it into a parking spot and stopped and offered to take me to my house so I could get my normal DD. I hop into that and go to walmart to get a copy of my broken key made, and the lady tells me she doesn't have any key blanks to make me a new one! She double checks and she had one blank in the back left so she was able to make me a new key and it works fine.
However, I finally get back to my car (with like 10 minutes until I have to be at class), and I press down the latch to open the gas door and the thing that would normally hold my gas door closed broke. I've got a few pictures of it, but I don't know how it was held in or should be.
This piece broke and is out of place and will not latch into the gas tank door:
I think this piece was threaded and held on so that it would hold the piece that moves in and out into position:
My cables worked fine prior to this, and I'm not sure of the easiest way to fix this. The threaded end on the inside of the gas tank door is pretty thrashed, I don't think I could get a new nut on there if I tried. Does anyone have any pictures of how it should be or recommendations on how I should fix it?
Thanks in advance.
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
you sure you weren't just pissed off and broke your key off being all mad and then upset about that and ripping off your gas door? sorry you had a bad day that sux
94_240sx
Car: 94_240SX
Well, your friend showed up when you were in trouble, and there was the last blank key waiting for you, so look at the bright side. It's not the end of the world, so cheer up!!! You still have your vert.
If you pull this piece gently, thread should show up and you can use that plastic nut to secure it.
You should be able to get to it either from the trunk or rear fender well. First, remove the passenger side fender well liner(17568Y in below pic) and see if you can get to it. It's right behind the rear wheel.
If the plastic nut is stripped and not holding the thread strong enough, you can get a new one. I think it's 84430B on the right side. Not 100% sure though.
Looks like you are missing the rubber trim that goes between the body and filler neck. Good luck and keep us posted.
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
94_240sx's reply FTW!
94_240sx
Car: 94_240SX
cmkelly wrote:94_240sx's reply FTW!
Haha! Thanks!!
This is how it should look like.
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
Nemo... That's area of your car is not spotless...
I respected you...
