KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Tue Jan 09, 2007 12:09 am
I'd get a gallon container of gas and drive it one day till it just runs out. Nissans like to read low fast, mine if its filled stays on F for a while then shoots way down to E within 150miles and then I put another 100miles on it sometimes. I dont think I've ever put more than 13gal in though.
But since you said it seems to be changing how much you put in at the same time, I think your problem is in the float. There is a little arm with some foamy material iirc on the fuel pump, known as a float. What this does is send a signal to your gauge telling you how much gas you have in it, those can be knocked out of adjustment or installed wrong and then give off readings. Best thing to do is pull the pump and check, if your not comfy then maybe a knowledgable friend could help or worst case, take it somewhere. Just dont smoke near it!!
There could be other problems as well that I am not aware of but a guy who bent his float arm installing a new fuel pump and now is 1/4tank notch = empty. That or you could have possibly put a large dent in your gas tank bottoming out?
