gas!!!!
abdow
Car: 1992 240SX
hi guys.i have a stock 1992 240sx. and this baby burns too much gas!! is there anything i could do. you know gas is expensive!! and when i open the gaS TANK. it releases too much air. i mean it makes a poff noise.
Modified by abdow at 6:37 PM 3/23/2008
bj_woods
Car: 1991 Nismo 240
i have the same prob. run some seafoam through it and it should help cause if yours is like mine then it burns gas like crazy.
Young_240_Guht
Car: "90 Nissan 240SX DOHC
I say negative to the sea foam, not a good idea.
Car is stuck? or stock? Maybe a MAF sensor, or time for a tune up....
I just tallyed up my MPG... 11miles to the friggin gallon...
kernan240sx
Car: 89 240sx
why negative to seafoam? I have heard GREAT things about this product! Im gonna try some in my gas tank.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
i use seafoam on my stock ka24de before i went ka-t and i felt a difference in performance.
it ran alot smoother and pull stronger.
but then dont know if its safe now since im turbocharged. is it?
brandonDavid
Car: 1992 240sx, 1992 D21
depends on how low i am on gas, but my 240 does the same thing when you open the gas tank, run seafoam, check maf. and then if that doesn't work i'm sure you'll have more suggestions on this thread by then.
Vegascorbin
Car: 1990 240sx dirt track race car
Remember the KISS principal
KeepItSimpleStupid
This is not ment as an insult, Just a reminder to not overlook the small simple solutions to problems. I have heard/used this for years.
For your problem just start with a basic tune-up. Plugs wires etc. Also remember to check tire air pressure as that will have a big effect on MPG.
If that does not improve your MPG then you can start looking at other options.
(sniff, sniff) (my two sents)
imphamus
Car: 1995 240sx
as far as that poof... my 95 does it also... and i get 31mpg which is far beyond epa estimates lol
imphamus
Car: 1995 240sx
240sxvaj wrote:i use seafoam on my stock ka24de before i went ka-t and i felt a difference in performance.
my buddy runs it through his talon tsi awd about every oil change... its completely safe
Young_240_Guht
I use a about a quarter of a tank to and from work wich is somewhere around 14 miles total... I changed the O2 sensor, cleaned the MAF, and my tires are up to 42 in the rear and 45 in front. Guess its time for some wires and cap... I dont smell it being pig rich, could the Cat converter be causing it?> I may just take those out and buy a new engine with the money from the insides of it!
Air filter is new, Ran Lucas through it, Plugs look fine, Compression is good. IDK
rxm6
Car: '93 240sx
Young_240_Guht wrote:I say negative to the sea foam, not a good idea.
HOLY WTF!!!!! That's doge viper status...you running 12's too??? Maybe you have an injector stuck open dumping fuel in....???
abdow
Car: 1992 240SX
m
man same here 11 MPG!!damn man gas is expensive. whAt can i do????
kernan240sx
Car: 89 240sx
put a can of seafoam in my gas tank, will see if it helps improve mpg? Gas is going to be SOOO expensive soon..its gonna suck...all them chinese people gettin cars isnt going to help the situation either!
