biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Thu Mar 10, 2005 8:02 pm
1.. what originalsin said plus if you have a walbro or otherwise bigger than stock fuel pump good chance you're overfueling from the stock FPR being a weaksauce POS, get a Nismo unit. Also, bad knock/det sensor, O2 and water temp sensors can make it run bad, not to mention if you've put in bigger injectors w/o a retune etc.2.. my stock KA cluster did that for awhile, then stopped altogether. it may be the cluster itself, or like originalsin said the sender. try whacking the dash above the cluster really good, that used to temporarily fix mine.. 3.. ditto, that smoke is just the crap you sprayed on it burning off4.. small amounts don't matter other than momentarily, if it was bad you'd know (hydro lock is baaaaad, you'd know if it happened)
