Gas Smell When I Start The Ride
Insane30T99
Car: working out, sports, working on cars, music
I HAVE A ? THAT MATBE SOMEONE CAN HELP ME WITH. WHEN EVER I START MY CAR COLD I SMELL A STRONG GAS SMELL. MY RIDE HAS 80,000 MILES ON IT AND IT RUNS GOOD BUT IS THIS NORMAL? IF NOT WHAT CAN I DO TO STOP THIS SMELL?
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
Check all the clamps on the fuel hoses and make sure they're tight. Some may be hard to get to... not sure on I30.
Good idea to replace the fuel filter if you haven't done so in the last year. Perhaps it's getting clogged up?
Does the car run OK? If it runs rough, could be other things too like airflow sensor.
:confused:
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Hopefully it will be one of these and not fuel injector leaks. I had the injector leaks in my old Maxima (these were recalled by Nissan) and the smell came through the vents. Is that where you are smelling it from?
Insane30T99
NAW IM NOT SMELLING IT THROUGH THE VENTS, BUT YOU CAN REALLY SMELL IT BAD WHEN THE CARS COLD AND YOU START IT AND STAND NEXT TO IT. DO YOU THINK THIS COULD BE THE INJECTORS? IF SO LET ME KNOW SO I CAN FIX IT OR TAKE IT TO GET FIXED IF ITS A BIG JOB. THANKS.
Eswift
Car: should be obvious enough
could be deteriorated fuel hoses, bad connections, a bad fuel damper, or a bad fuel pressure regulator. I had a 94 J30 with that gasoline smell at startup and that turned out to be the culprit.
BadQ45t
I think that is probably right, the fuel lines should be checked out first, I had to replace those on my maxima too...hope to god it isn't the fuel injectors! Check out the fuel lines first.
alexhho
Insane30T99 wrote:NAW IM NOT SMELLING IT THROUGH THE VENTS, BUT YOU CAN REALLY SMELL IT BAD WHEN THE CARS COLD AND YOU START IT AND STAND NEXT TO IT. DO YOU THINK THIS COULD BE THE INJECTORS? IF SO LET ME KNOW SO I CAN FIX IT OR TAKE IT TO GET FIXED IF ITS A BIG JOB. THANKS.
Did you ever solve the problem? I have the same problem on my 97 J30 (50,000) miles on it at startup. But the gas fume smell quickly goes away once the engine warms up (a few minutes later). Just wanted to see how much the cost would be to solve this problem. Take care.
