Hi Buck, been there, fixed that. On mine it was especially noticable in colder weather. You will have to contort yourself a bit to look forward just in front of the firewall on the passenger side. On mine I could actually see the leak when I stared it cold. It is a small rubber fuel hose connecting to a steel portion of line. This was several years back and I had read that you had to take the plenom off. Not the case with mine, I was determined not to do this and succeeded in getting half a turn or so on the clamp. No problems since. I used a
very long slim straight screw driver if I remember correctly.
Hope this helps.
