My RB25 »
https://forums.nicoclub.com/my-rb25-u61932.html
Sat Feb 02, 2008 9:24 am
Hitting the pedal in a fuel injected car has no bearing on starting it (It's not a carb, where is shoots gas everytime you touch the pedal). Unless it's flooded, some cars have a method if you go WOT while cranking it will clear out the cyl's. I push down on my gas pedal before starting (or after), before I pull away cause my throttle has a tendacy to stick sometimes, especially if I'm rev matching, slowing down for a light, come to a stop and wait a few min. Pisses me off when I stall like that Letting out the clutch, but no gas, makes people think it's your first time driving stick lol.
There's not suppose to be any puddels near the injectors or anywhere under the hood. Chances are its an O-Ring, but if there is a puddel, you should be able to see where it's leaking fuel (considering the puddel is fuel). There's two o-rings on the injector, one for the fuel rail and one for the manifold. If you do check them, make sure to de-pressurize the fuel system first, gas in the eye's doesn't feel good.
There's a ton other things it can be, but your best bet is give it a good visual inspection first. Make sure your fuel rail isn't rusted out or anything like that.
