gas smell from under hood
golfboy240sx
Car: golf
Just bought a 90 240sx se. Noticed while I was driving that could smell gas inside the cabin. Checked everything but seems to be under hood but cannot find where there would be a leak in the fuel line. Anybody have their cars do it and maybe somebody could tell me what it is so I can fix it fast. Engine has only 93,000 on it. By the way, I had never driven one of these before but I can't believe that I will ever go back to a front wheel drive again.
thanks everybody.golfboy240sx:ylsuper
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
Check the injectors you might have a bad o ring and go over the fuel line one more time, at idle the pressure is low so a small crack might not bleed off fuel but while driving it will leak.
Chally
Car: '94 Infiniti Q45
2002 Nissan Patrol 4.8L
2013 Citroen C4 (economy)
Check hoses to carbon canister & the canister itself to make sure there ain't any cracks or breaks.
Nismo1182
Car: Z06
golfboy240sx wrote:Just bought a 90 240sx se. Noticed while I was driving that could smell gas inside the cabin. Checked everything but seems to be under hood but cannot find where there would be a leak in the fuel line. Anybody have their cars do it and maybe somebody could tell me what it is so I can fix it fast. Engine has only 93,000 on it. By the way, I had never driven one of these before but I can't believe that I will ever go back to a front wheel drive again.
what part of florida are you in? Anyway, my 90 has the same problem and its the injectors. Look around the ends and you will see fuel leaking out slowly.
golfboy240sx
Car: golf
Thanks, took it back to lot and said that it was upper O-rings on injectors. I live in Bradenton/Sarasota area. thanks:ylsuper
rschwalbe
Car: Weightlifting and my daughter
Same thing happening to my 90 240sx with 108k and has been going on for about 2 months and just found the same issue including the injectors all beed to be replaced!
On a side note I am up here in St. Pete and used to live off Beneva Rd. in Sarasota!! Parents still live there!
rschwalbe
Hey Chally, whats the carbon canister you are talking about?
I_eat_hondas
Car: my car and my new baby boy Caleb
Hey Chally, whats the carbon canister you are talking about?[b/]
the canister is in the front of the engine bay on the drivers side, the hoses run across the radiator on the fan shroud, check all of those hoses. I found the leak in mine on the high pressure fuel injection line leading into the fuel rail. check around the clamps
rschwalbe
OK--but what is the canister for? What does it do? Do I need to replace it? And do I really have fuel lines running all the way up there and then back to the fuel system??!
sil80drifter
Car: 1990 240SX Hatch
It collects fuel vapor from the fuel tank, condenses it to liquid fuel, and runs it back to the fuel tank. When you open your gas cap to fill up, and you hear a hissing, it means the canister is not keeping up well (maybe needs to be replaced). Usually the hissing happens on an almost empty fuel tank, in hot weather, so that's normal.
sil80
