Suck it up! it has 250 hp and is smooth as silk.moseng wrote: I recently bought a 2001 pathfinder (well, 2 actually but the first is totaled) and coming from a much smaller non SUV type car find it to be well... a gas hog! Not that I didn't expect it but WOW!
I have been looking for ways to try and squeeze a few extra mpg. Short of riding my bicycle I have been surfing the net for suggestions. Hmmm, what people will come up with from magnets on the fuel line, to acetone in the tank, to little tubes of who knows what going who knows where! I mean none of this stuff actually works does it?
I decided to try a radical new approach! Oh, I will be selling an ebook on this if you're interested! Really though, just the basics like regular maintenance, not stepping on it at every light, etc.
So, how do I monitor my gas mileage? I could just record the number of miles and divide it by gallons used but I was thinking something real-time might help me notice my lead foot action. After looking at a number of devices I have pretty much decided on a Scanguage II http://www.scangauge.com/ . I think this and a little common sense will help me shave a few dollars at the pump! Oh damn! now I have to figure out how many gallons I will have to save to pay for the Scanguage!!
Do you (assuming you try) have any gas saving techniques?
QX4ME wrote:On some Honda Oddysey, there is the Variable Cylinder Management which will turn off I think three cylinders at highway steady speed.
If you could install a switch to manually turn off the fuel injector like #1, #3 and #5, or #2, #4 and #6, as well as their corresponding spark circuits, that might be a good gas saving way. I know nothing in details how to do it, but just an idea from Oddysey.
Any gain in efficiency by not spraying fuel on 3 cylinders would be then lost by merely compressing air with no return value. Only way you can "shut down" cylinders and not completely suck is to then intruduce a variable-lobe camshaft so you're running the intake valve open on 2 of the 4 cycles and the exhaust open on the other 2. You're still losing efficiency, tossing dead weight around, but if fuel economy is ALL you're after, I suppose it would do the trick. But efficiency isn't on most people's minds. And sorry, moseng..didn't mean to come off on you hard, I thought you were being for real about the ebook douchenozzlerie. You can strip weight, make the pig as "aerodynamic" as possible, you're still never gonna get better than like 22 mpg. Hell, I have the full roof rack, lights across the top, whip antennas, my spare tire and I run fat A/T tires and I still average 19 mpg. I used to get 16. I also used to drive 80-85mph everywhere in Cali. Now I'm running 60-70 on the roads here in NC. It's all in the final drive RPM. As soon as you bump over 2k on most any motor for long periods of time, your fuel economy goes to sh*t.QX4ME wrote:On some Honda Oddysey, there is the Variable Cylinder Management which will turn off I think three cylinders at highway steady speed.
Heh! I guess that is the best advise so far!pathfinder9035 wrote:
Suck it up!.
I would like however to ask one more question, hopefully without getting slammed! Regular or Premium gas?
Most of you know I live in Tokyo Japan for most of the year, and this is so true. Actually the best way to tell if someone is a gaijin (outsider) is they are the only ones who don't back into parking spots.K03sport wrote:13. Always back into parking spaces. Your engine is warm and buring efficiently when you arrive. When you leave, you can drive forward and not have to waste time backing up. (It's all the rage in Japan...seriously, they do this.)
i like most of these - the ones having to do with weight reduction as well as modifying driving style. intelligent driving with minimal stopping is EVERYTHING - not only for MPG but wear and tear on your vehicle as well!!! and it gets you places faster!!K03sport wrote:Interesting outlook on the N. American fuel there sicwitit. I'm not a conspiracy theorist, but it sounds like it makes sense. I know there are summer blends and winter blends and CA blends, so this detergent thing is plausible.
Here are some MPG adders for your online book "moseng". The idea behind them is to save fuel, so they may not be too practical in other respects:
1. Air tires up to 45psi cold.2. Buy skinniest tires you can find in your wheel size that will support the load of the vehicle, then see idea #1.3. Never drive over the speed of 45 mph, never over 40 mph would be even better. (Air resistance increases by a factor of 4 as speed doubles.)4. Remove as much extra weight as possible - no spare tire, not tools, no jack, etc. 5. Never tow anything.6. Always drive with the windows up and sunroof closed.7. Never go through a drive-thru window anywhere, even if you are the only car...go in and get your food, etc. 8. Shut engine off at prolonged stops - railway crossings, long red lights etc.9. Change your spark plugs every 12 months, regardless of mileage.10 Change your air filter every 12 months, regardless of mileage.11. Switch all fluids to synthetic - diffs, transmission, oil, T/C if 4WD12. Buy smaller, 11lb racing battery.13. Always back into parking spaces. Your engine is warm and buring efficiently when you arrive. When you leave, you can drive forward and not have to waste time backing up. (It's all the rage in Japan...seriously, they do this.)14. Replace hood with carbon fiber replica.15. Never fill tank over half full. If 1 gallon of fuel weighs 7lbs, a 1/2 tank will save you about 56lbs of unneeded weight.16. Never stop moving once you are driving. Steady state cruising nets you the best mileage. Its the starts and stops that bring MPG down.17. Anticipate red --> green lights, but don't hold up traffic.18, Get off the gas sooner when approaching stops. Let momentum carry you and if you are lucky, you may not need to stop completely.
Well said. If I wanted to save gas I would have purchased a Honda civic. However, if there is one tip that I could give that probably save the most gas of all these tips it's use a GPS unit. When I first got GPS years ago, I was surprised how inefficient my driving routes were. Even the small routes around town, the one's I thought were the fastest or the shortest turned out to be some of the longest. A lot of GPS units allow you to set the route to shortest or even economical (I think Garmins have this feature) so it will give you the flattest route or the route with the least amount of stops. I started using GPS for every little trip I made just to learn the shortest routes around town.sicwitit wrote:face it, our vehicles are a utility class automobile, not an economy class vehicle. if you want economy, then buy something that saves fuel from the get go. this is part of the problem with society today, mainly in America. there is a whole economy set up to make people worry about things like this when the real problem is people arn't making smart choices to begin with.
Sure you can save a couple dollars at the pump, or squeeze one more days driving out of a tank with all these things, but in the end whats the difference. Learn how to combine your trips, set waypoints to minimize the actual distance traveled. conserving energy is what needs to be practiced, not how to raise efficiency by only .08%
I have a number of vehicles, My IS300 when at full throttle, might on a good day get about 6-7MPG with all the work done to it. My pathy 15-20mpg. Each has a specific purpose, and I expect nothing but. I also have a couple motorcycles, I have seen 1 gal last me for 70 miles with consevitive driving on my R6, so with a 3.5gal tank, that will take me close to 200 miles of driving with a couple of wheelies here and there.
aww hell, what do I know anyway!
