gas question
fogged306
Car: 1997 j30
Oh and they will throw a code so tell you there's something wrong... telltale sign on OBDI cars is the CEL coming on and going off randomly. That usually means on o2 sensor is on its way out.
gr8scott72
Car: 1994 Infiniti J30t
fogged306 wrote:Oh and they will throw a code so tell you there's something wrong... telltale sign on OBDI cars is the CEL coming on and going off randomly. That usually means on o2 sensor is on its way out.
I think it does that for many of the codes. I know it does it for the EGR code. And if the light comes on and goes back off, you should have a stored code in the ecu that you can pull.
steverinaz
Car: Hello!
2213
Greteings J30 fellows;
I too have yet too have my low fuel light come on. I just filled her up at 1 click above "E" and it took 14 gallons. Yoda- I like your idea, but seems gutsy- LOL! I guess I'll buy a 1 gl can and try it. :chuckle:
1994 infiniti j30 190+
1990 Ford Ranger XLT Sport Limited Edition
and having a functional egr is one thing that will greatly effect mileage. also any vaccum leaks will effect fuel mileage. i had to do my cam seals and once i did those fuel mileage went up along with other hoses that were drying out. also having rusted out exhaust will effect that (personal experience for me) i went from about 13 mpg city avg. and right under 200 miles to the tank in city to about almost 18 mpg city and depending on how i drive it almost 250 to 260 miles to the tank. 16-17 gallons when i go from empty to full. i have never had my light come on and i have put in once 17.5 gallons in.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
ive been to the low fuel a few times just for the heck of it. i currently dont have egr or my prvr but with the manual trans im avg about 22 mpg. making 194rwhp and 170ftlbs. think i was getting about 28mpg on the way to and from nashville for an import alliance car meet.
yodawill2000
Car: 94 Infiniti J30
FYI I did finally get the low fuel light.
Stuck in a MASSIVE traffic jam.
It came on when the needle went a tad under the "E"
Bailed off the freeway and filled her up.
I was happy to see it and a nervous wreck getting to the gas station all at the same time !! LOL
J30tChumpCar
Car: 1995 J30t Totaled @ Charlotte motor speedway
1994 J30 gutted caged road racer Now with VH45DE!
1966 Chevy Corvair V8 mid-ship conversion
I will have to ask our crew chief how much gas we were putting in at pit stops but the gauge would read empty or one line above with no sputtering under race conditions ,the lack of sputtering indicates there was plenty of fuel available while on E
GerryO
Car: 1993 J30t
Pearl White
Black Interior
yodawill2000 wrote:FYI I did finally get the low fuel light.
So how many gallons did it take to fill 'er up? I have to work to get the needle to go to or past Full when filling up, and it quickly drops to 3/4 of a tank after 35 to 50+ miles of driving, depending on whether it's stop and go or freeway miles. The needle stays near 1/2 tank for the longest time.
I understand that some gasolines are worse than others when it comes to leaving sulfur deposits on gas gauge tank components and have always believe that Nissan designed the gauge to work with a fuel tank whose dimensions are perfectly rectangular (the J30 tank holds less volume per inch nearer the top).
steverinaz
Car: Hello!
2213
Gerry;
My 96 acts like yours. To get it to the F takes patience and determination and after about 50 miles, starts dropping rapidly. I've always been one to keep a minimum 1/2 tank in my cars. Each time I get to E or a click above, it takes 14 gallons. This tells me that there'a at least 5 to go (or there abouts) on E. I've never had my light come on, suspecting a burnt bulb. But after seeing what Yoda wrote, I will assume it's ok and only try it one day when I get gutsy enough and have a spare 2 gallon can in the trunk. The tank I know is not square, nor round, but somewhere in between.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Filled up this am with the needle almost on E, taking 13.2 gal (285 miles of combined highway/city driving) and getting the needle not quite all the way to F.
