...ok y'all....something you should be aware of, itdoes happen, not alot, but it does happen.....
If you think that when you fill up with gas that it ends up taking too much, (more gallons than yourtank is supposed to hold), try this the next time atthat same place that you filled up, or, at the place that you usually fill up at...
Some places have been caught at rigging theirpumps to show and charge for gas that you didn'tactually get, so.....here's the check:
Next time you get gas, only put in exactly 10gallons according to the pump reading, then, dothe math...your dollar amout should be exactly10x the price per gallon.....really, some stationshave been busted for fraud.....so, check it to besure of your usual place that you get gas,especially if it doesn't seem right.
