03gz wrote:my g wastes lots of gas...i filled the tank to see how long it would last me an i drove my car from work an back an to the store a couple time i did about 200 miles in about 3 days and my tank was empty...is that normal???
03gz
Welcome to NICO
Do a search as this topic has been discussed many times.
I keep careful and detailed records of my MPG. My last three fillups returned 22.40, 22.93, and 22.36 MPG. I commute and drive 100mi per day aat 65- 70 MPH. My tire pressure is 38 lbs when cold and I keep my air filter clean and replace it every 10k miles or so. If you are not filling your tank in the early morning or the coolest part of the day that may be a contributing factor to your poor mileage? Another controversial topic is the type of fuel. Although the owners manual recommends and many here on this site use premium, I do not. I've used regular 87 octane since day one and with 52k miles on my G I have not experienced any problems nor have I noticed any performance issues. I have noticed that my G runs better at temperatures in the 40 to 60 degree range than it does at 10 degrees and the MPG improves 1 to 2 MPGAlthough I can't prove it, I suspect that regular 87 octane may provide slightly better MPG?
There was a recent post that mentioned not filling the tank at the highest flow rate setting of the pump to reduce the amount of air in the tank. Although the G is a very fun car to drive, if you are flogging it every time the light turns green that may account for part of your poor MPG problem?
Telcoman
