Gas pedal only goes down 1"? Can push through jam?
mattleegee
Car: s13+19 corolla
s13rb25detstock s13 throttle cablestock rb25det intake manifoldrb25det custom throttle cable bracket
Problem:Cannot put the pedal any further then 3/4-1" Its like at a stopping point, but if i apply ALOT of pressure i can get it down to the floor, the first time i did this while driving and im still slapping myself for that
Once that point is reached pedal will move smoothly but only when not running, a restart of engine or anything the pedal with be "stuck" again where i can only press about 1inch
Any help?
*Throttle cable has full movement from all the way closed with pedal up and all the way open when pedal to the floor*Idle is fine, it returns all the way closed with foot off the pedal*No matter how many time i "reset" the pedal by forceing it past the point, as soon as i start up again and go for it it gets "stuck" again*Lube was applied to the throttle cable pulley and gas pedal to see if that would help.... no dice*Also pumped the pedal with car off to make sure everything was moving good ... no dice*The throttle cable is not kinked and tried a few different postitions to see if it would help
This is probably really easy but my searches are not working that great, thank you in advance
vin diesel
Car: 99 328i
can you freely rev the car from the engine bay
mattleegee
Car: s13+19 corolla
I will try, i brought it up a little but didnt try to pull all the way when it was on
mattleegee
Car: s13+19 corolla
Just spent a couple hours playing with the cable and stuff
When the pulley/cam is pulled it works perfect
I got one good run when it was working right for like a 1/2mile and then shut off the engine and restarted and it was stuck again
Some more troubleshooting:When it was stuck instead of pressing down really hard on the gas pedal i decided to pull on throttle cable (while off) i moved the pulley about 1/8 of a inch and magicallly it would go down all the way
Someone has got to know.... please
mattleegee
Car: s13+19 corolla
wow ok...so i starting drinking beer and was thinking.... why would it get stuck when i pushed it through..?so i took it out for a spin but i forgot to close the hood all the way, holy s*** it actually goes all the way down.... close the hood it doesnt go down right... allright stupid, press on pedal with car off and hood closed and hood is poping up and down...
.....hitting the hood
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
glad you figured that out
mattleegee
Car: s13+19 corolla
it was so stupid but spent the last few days trouble shooting, too freaking busy takeing off the throttle body, adjusting the cable, and checking the pedal to actually just take a momment to notice it was hitting the hood... argghhh
it was great though... first time i got to take it out and get on it a little, i stayed closed to home incase something happened but im excited now
it hits the webbing in the hood so im just gonna cut out a slit and hopefully that works
vin diesel
Car: 99 328i
what mounting kit did you use
mattleegee
Car: s13+19 corolla
stock r33 mounts and r33 crossmemberspaced and redrilled to use stock clutch fan and lower 13mm
