Gas pedal gets stuck sometimes
youngcoke
I have a 1999.5 nisan pathfinder.sometimes when i try to press on the gas pedal it is very hard to press on
it happens sometimes when i stop then i go and somtimes when im going in the free way and not pressing nothing but when i try to press on the gas pedal it is i have to put pressure not alot but i dont think its normalhel me? o yeah were is the gas filter located at
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
try cleaning the trottle body
youngcoke
throta
pathfinder_se_black wrote:try cleaning the trottle body
trottle body what is that and were is that thnak you
pathfinder_se_black
youngcoke wrote:throtatrottle body what is that and were is that thnak you
i meant to write throttle body, sorry typo error, try using bg44k fuel injector cleaner too. i had a similar problem with my old car.
tjelly
Car: 1990 Nissan pathfinder
Go look at the spring that pushes pedal back and see if there is a grove in the rest position where the spring touches the pedal bar. If so use a file and remove grove. Found that on 97 pathy
youngcoke
That was the problemThanks
